Toilet stack
10 Nov 2025
so, i have cut the toilet stack that's runs down the middle of my sitting room so I can join in a tee piece. But the inside of the pipe has water dripping from it, ( Quite a lot really) but there's no sign of overflows running or pipes ,/sinks from above leaking into it. The soil stack sops in the loft so no water coming in from rain etc?
Anyone know what this could be?
Condensation? But sounds unlikely if it's actually 'running' with water.
Sounds like you've missed something, an overflow or condensate pipe for example. Maybe something from a water-tank in the loft?
Perhaps go to all of your appliances, boiler, basins, shower, toilet, heating system and trace actually where they do drain into each. If not obvious then maybe this is your cause?
Thanks guys, I'll try all these, I think its a bit much for condensation! I know condensate pipe is on a boiler, and overflows on toilets and sinks is this correct? If overflow in toilet cistern can't you usually hear it?
So ok, its not condensate from boiler that's piped outside. Surely it can't be taps as you'd see it, so its gotta be one of the 2 toilet cisterns ye?
Many thanks everyone. it was running from the cistern back into the pan. My nephew (a plumber) told me to flush toilet dry the pan then stick a piece of toilet paper up near the rim, it should remain dry. It was sodden within a minute.
