Too keen to start tiling?
1 Oct 2006
As many of the regular tiling contributers will know, I am about to embark on my first tiling project- a bath room.
I have installed a new shower (well the plumbing and cabling, and had to do a lot of remedial work filling etc. This means that the plaster had to be applied quite thickly in some areas- for example filling behind where skirting boards were, and where I had to cut out channels for pipework and cable.
This plaster is not 100% dry yet. It is dry to touch, and appears to be set firm, but it has not yet reached it's final dry colour (I think it was done about 4-5 days ago).
Can I start waterproofing and tiling (I am holiday this week, so getting started would be a major help), or do I have to be more patient?
You have to be more patient - if the plaster isn't dry yet then it's not up to full strength. BTW, why did you plaster if you're going to be tiling onto it? :?
Just to fill in the huge holes my angle grinding had caused- had to cut big channels to submerge the cables and plumbing. Also I ripped out the skirting boards, and there was no plaster behind- so no suitable surface to tile onto.
I was hoping to get away with tiling as the channels are only about an inch wide, and the plaster is sound either side- so the weakened area of plaster will be pretty small on each tile- a 1 inch vertial line. (the tiles are 13" horizontally by 9" vertically).
I could start on one of the other walls, but it seems to make sense to start on the back wall so I get a better idea of how it will look.
I wouldn't be too bothered about tiling over an inch wide channel with the size of tiles you're using. I think I'd leave it a while longer on the larger areas like behind the skirting though.
Thats what I was hoping you would say- the skirting board bit will be done last as it's the bottom row of tiles!
I will start tomorrow! :shock:
I thought you're supposed to leave a gap of about 2-3 inches because this is where the groundings are located for the skirting? :? In other words, the bottom edge of the bottom row of tiles should be 2-3 inches above floor level. Then skirting on last.
Yea, but you didn't need to plaster over the gap left by old skirting as you don't tile over this gap anyway ;). I mean I'm sure there is no right or wrong way, but I don't think that you would normally do it the way you have.
Hehe you and me both m8 :).
Tozzy,
There won't be any skirting boards whaen finished- I am tiling the walls flush down to the soon to be finished floor.
Anyway- I have just realised I can't start until tomorrow- so the plaster should be virtually dry by then anyway.
Oh, one other reason for plastering was to give me a better surface for the waterproofing to stick to.
Sounds to me like it's a wet room then. It's just, our bathroom has skirting, but then again, we don't have a shower; just a bath. Would you add skirting if it was a tiled WC?
I wanted a wet room, but felt it was probably beyond my abilities for a first attempt. Also the drainage for the floor was expensive, so I decided to go with a fully tiled bathroom instead.
