Tricity Bendix DH 090 Dishwasher
11 Jul 2015
Hi
Dishwasher hasn't been moved or anything altered to it.
Noticed a week or so ago that glasses didn't appear rinsed well, but had washed. Changed tablets - still the same.
Watched a cycle - drained, filled, but looked like not enough water. Looked like it then went through without rinsing.
Turned it back to start and it didn't fill. Tried the following day, and a little water went in.
Therefore to me it appears that the water inlet valve is working, just being told the incorrect amount of water is in there?
where is the water switch / is it air pressurised etc?
Any help appreciated
took out all the normal filters and this leaves a little dome with a screw on it (inside the wash area on the right hand side) Removed the screw on the top and lifted off the dome. Inside are 3 little tubes ( 2 the size of a pen and the other a little smaller ) Took a picture of these so I could put them back correctly. Note of the 2 large ones, one is slightly larger. Cleaned them in a bowl of water and re-assembled.
So far so good - all working fine..
Underneath the machine directly under the two syphon tubes is another c shaped clear hose,you need to clean that as well.
so turn it on its back? or do you mean inside by the dome? I cleaned another little tube by there too?
cheers - recovering from an operation at present so will have a look in a week or so - cheers
