Hi Guys,
I have a leaking Triton Dove mixer bar. I think it is the flow control cylinder and I have bought a new one.
I tried to turn off my stopcock today to drain the cold water system to change the faulty item.
Because it is a mixer bar do I need to drain anything else apart from turning off the main stopcock under the kitchen sink? I was thinking that it might be fed hot water as well being a mixer bar.
Also, I ran the taps for a few minutes and the water didn't stop coming out of the cold water tap, Did I do something wrong or miss something out?
How long does it take to drain a cold water system with a normal semi detached house size water tank. It is a water tank in the loft system not direct fed.
Any help woild be great.
Ed
Ed
