In Oct08 I had my old Myson boiler (on an open vented system) replaced with a new Vaillant system boiler (on a pressured system). Ever since then I've had problems with the three port valve. Intermittently I find the heating won't come on because the valve won't wind fully into the heating only position- it will only come across as far as the mid position or slightly further and then stops, which means I only get heating if the hot water is on too. I discovered I can temporarily fix the problem by moving the lever across manually into the heating position- it will then work by itself again for days/weeks before the problem repeats. It did this a lot between Oct and Dec but then British Gas (who support the system) changed the whole valve for a new one (head and body) and since then it had been fine, so I put it down to a faulty valve until today it happened again.
Co-incidentally (?) I bled a radiator last weekend and then topped up the system- but because I can't see the pressure gauge when I'm operating the fill taps I managed to end up with the pressure slightly higher after than before (1.4 bar when cold instead of 1.2 bar). Not being at all technical all I can guess is that maybe the valve motor struggles more to go in the opposite direction to the spring if the pressure in the system is higher?
Any advice gratefully received- if I call BG out again they will tell me they only changed the valve four/five months ago and threaten to charge for another new one- and that might not solve the problem either. Please dumb it down for me though- I'm a female IT project manager and I've put everything I know technically about this into this post already!
