type of shower advice please
  • Thread starter Thread starter angelf
  • Start date Start date
A
angelf
Cold tank is not one metre above where we would like to put our shower. Is there any electrical showers that can be installed where there is a height problem & therefore pressure problem with regards to water & water supplies?
Property is a terraced house 2 bed flat roofed property. Shower to be fitted on the second/top floor. The boiler is a 15kw conventional system.
Do the hot & cold supplies have to be run of the tank/cylinder supply or can the hot & cold supplies for the bath be extended for the shower.
cheers.
you've got a choice of quite a few shower.
you can have an electric shower that is fed from the cws in loft
but still needs a large cable run back to the consumer unit.
you can have a mixer shower fed from the cws and the hw cylinder
with an additional pump added next to the hw cylinder to boost the shower supplies.
that can be wired to a 3 amp spur
you can have a power shower with in built pump fed from the cws and hw cylinder. wired to a 3 amp spur.
or you can have a digital shower with in built pump fed from the cws and hw cylinder. wired to a 3 amp spur.
depends what you want to spend.
