Hello all,
I have quite a large project going on at the moment and are undertaking a chunk of the work ourselves,
We are extending a typical ‘2 bed & a box’ semi two stories at the side & also single story at the rear,
We have done a few months on it now, ripping out old stuff & have a builder starting in the next few weeks to put up the shell but after that we are on our own, so I find myself spending most of my nights reading forums about everything from the insulation values of insulation to how to sink steel beams in a floor..
The plan is to install UFH throughout downstairs & in the bathroom.
After much deliberation and reading of threads I am planning rip up the floorboards & use the aluminium spreader plate system downstairs. I know this is slightly more expensive than screed but I have concerns about alot of additional weight.
I am going with engineered wood as the floor covering but I was wondering if I was to lay down 1mm thick aluminium plates between the floor covering & the UFH spreader plates would this improve the heat dissipation/distribution?
Currently I am thinking it could be benificial as it is surly going to increase the thermal mass of the 0.3mm UFH spreader plates,
I cannot find anything on the net about this option, and there is normally a good reason for that!
The main reasons behind me considering this idea are
1. If it does increase the efficiency of the UFH greatly at a slight cost in reaction time then great
2. I can get these plates though a friend quite inexpensively
3. I am wondering about a bouncing effect when walking, of using unsecured engineering board straight down on joists and would think a conductive material would serve better rather than another insulator (eg 5mm plywood)
I would appreciate any comments on the above idea,
