I currently have a wirsbo manifold located aprox 25cm from floor level in a utility room cupboard.
The manifold has been a pain recently with sticking valves etc etc.
I am looking to replace it with an Uponor vario B manifold with flow indicators but i note the instructions say to mount it a minimum 300mm from floor level.
The only reason i can think of for this is to make it easy for access and install????
I will need to drop the manifold to around 20cm from floor level due to replacement of the couplings with eurocone types.
Only other option would be 18 repair couplings and lengthen the 9 loops which would, i suspect be a recipe for disaster.
