Hi there
Got a Vaillant Turbomax 242e. I noticed the rads had gone cold early tonight so ventured upstairs to check boiler & discovered it wasn't firing.
Switched it off & on & discovered that the fan light blinks on as if it's going through the normal firing procedure but doesn't stay on. Pump is working, fan is working but boiler not firing. Boiler pressure is fine at just over 1 bar and everything else was working fine until this evening.
Have read through the fault finding chart in the instructions & it seems to lead me to the air pressure switch which it recommends "checking or replacing".
Anyway, given a couple of bad experiences with heating engineers I'd like to be a little forearmed with knowledge to avoid getting ripped off again.
Anyone got any ideas - is it nailed on to be the air pressure switch or am I barking up the wrong tree?
Thanks in advance
Cheers
Smudger
Thanks in advance
Cheers
Smudger
