Vaillant Turbomax Plus 824EH
1 Nov 2008
Liverpool
Hi everyone,
I have this Vaillant boiler installed in the garage. As you will probably be aware the water is instantly heated when any of the hot taps are turned on. there is no water tank.
The heating (radiators) are controlled by a analogue rotary thermostat in the lounge. It an Eberle (similar to a Honeywell T6360B) and is a 4 wire connection.
I want to replace the thermostat with a digital thermostat that also has the capability to be set on a timer to turn on in the morning and off in the evening.
I am confused as to whether I need something like a "digital thermostat" or a "timeswitch". ie: (digital thermostat) Drayton Digitat +3 or do I need a Drayton LP711 (timeswitch) / Danfoss TS715si ?
What's the difference ?
Thank you
Hi everyone,
hello lfc84
for 'plug n play' look here 340f and 340f
ok thanks, but i would prefer a wired unit since i t wont cost as much and the wiring is already in place.
anyone else got any options for me ?
thanks
