Very low cold water pressure but good hot water pressure?
21 Jan 2006
Hi. I would really appreciate any advice on my problem.
I am in a 1984 manufactured home. I have been here 2 years. I don't think the problem was as bad when we first moved in?
The hot water is good at all places in the house.
The cold water pressure is very bad.
When you take a shower you have the cold water valve all the way on and just crack the hot water open. If someone flushes a toilet whatever sink you are using, you might get burned.
The cold water just dribbles into the wash machine.
The main toilet fills faster than the one in the master bath.
A couple of months ago the water company changed out the meter. When he was finished I asked him about this. He measured the pressure on an outside spicket and said it was right in the perfect range.
Thanks in advance for any help.
I forgot to mention all the water supply pipe is the plastic kind with compression fittings.
