I have a strange intermittent problem with my CH Boiler - every so often (about once a month) it will sit with a temperature of about 21 - 26, and regardless of the CH demand being called, it never kicks in.
I've tried the reset, but it doesn't seem to work.
It does however to 'fix itself' which is more worrying - after a while it'll just start working normally!
any clues..?
If this was a permanent fault I'd get someone in to fix it asap, but you can be damn sure that when anyone turned up, it'd be working fine, and 'no fault found'!
any clues..?
