- Joined
- 23 Jan 2014
- Messages
- 4
- Reaction score
- 0
- Country
I have a Linea 28 - installed c.10 years ago. I've recently had a problem with the radiators getting hot even when the heating is switched off, and also the hot water not getting as hot as usual. Central heating was working normally.
A gas engineer has been working on it, but the problems seem to be escalating and I want to find out if this is usual.
First he fitted a new diverter valve.
The hot water was still not right - alternating between hot and cold. So he then fitted a new heat exchanger.
In the process of re-filling the system, the boiler overheated, and could not be reset as apparently the control/reset knob was not working.
He has fitted a new control knob, but now there is apparently a problem with the main circuit board and I am advised that this also needs replacing. I can't understand this as it was fine before he fitted the new knob.
I am therefore currently in a position with no heating or hot water (after having heating and lukewarm water at the start), and a bill that's increasing with every problem.
My questions:
- are all of these problems normal / feasible?
- is it possible that any of these problems has been caused by the gas engineer?
- could the circuit board problem be something simple like it's not been put back together properly?
- is anything else likely to be wrong?
- is the boiler worth fixing further?
Thanks for any advice you can give.
My questions:
