Guys,
I wonder if you could assist in a little problem I'm having. The NTC sensor on my Vokera boiler developed a fault, so with the aid of my servicing/installation guide I changed it. All went well other then now when the boiler tries to fire up it ends in displaying an error code '1'.
Although I drained the boiler a little water did find it's way towards the PCBs, although covered I suspect a little water entered the casing. I checked this and found evidence of it but nowhere near the main board!
What actually happens is that when I turn the boiler on at the mains and select DHW it ignites successfully but then goes out after literally 2 seconds.
I'd appreciate your advice as to what the problem may be. If you could point me in the right direction as to where I need to look and what I need to test I'd be really grateful. I'm good with a multimeter so will happily test any components you may think are faulty!
I'm hoping it's not the PCB but I'm not convinced!
Many thanks in advance,
Tank
Tank
