Vokera option 24 help needed.
10 Sep 2008
Ayrshire
Hi can anybody give me an idea on how to increase the heat of my central heating.Had a a new pcb fitted as the boiler wasnt firing up.Now it fires up but the central heating is half the temperature it should be.I think before you could remove the buton which determines if you want to use central heating or hotwater or both and turn a screw,but the new board has plastic covers over the holes with no screw in sight.Please can anybody help.
Don't know this boiler too well, but the new pcb may well have a ch pot to set for output :?
Cheers Dave, i got a look at the pcb and managed to spot a hot water potentiometer and a central heating potentiometer.one was p1 and the other p3 so i turned them anti clockwise following the arrow.Hopefully it will improve the heat.
