i just find the seal on the toilet that the flush pipe goes in keeps pushing into the toilet rather than holding position. also the mounting is just two threads, will thhey really hold without bending?
Put the flush pipe connector onto the flushpipe then hang the toilet loosely and if you can slide the connector into the toilet but you will need plenty of silicone.
Or alternatively use a different flush pipe connector from the one that comes with the unit.
its a frame one, and with the aquapanel mounted over frame, i just cant see anything as the toilet closes up, may need a torch and mirror to put behind so i can try and see
The flushpipe connectors that come with these units aren't exactly great they are a wee bit to flexible but you can get more rigid ones that don't move as you push the flushpipe into them.
We call them adaptus (sp) joints ,they cost about a £1 or so you'll get them in any decent plumbers merchant.You might want to give that a go.
