Help!!!! I have a zanussi electrolux 1200 that is being stubborn. I have run several cycles to see if it will re-set itself but after all these attempt it still is not opening. What should i do other than brake the door.
Thanks for the reply. Yes i have waited after each attempt. I have also been told to turn the power off as well and wait 2 minutes but this never worked. I have banged the door to see if it would dislodge but that too did not work hhhmmmmm.
