water coming in from upvc door.
9 May 2013
Ok, my living room door has water coming in. i have no idea how long this has been happening, as we rarely use this door, but today its pouring down and i noticed it when cleaning, it could be months/years.
i have included a picture of what is happening.
what i would like to know, is can this be fixed, as there is no way i could afford a new door now. could it be the rubber seal is broken or something like that? either way i wont be repairing it myself, so i came here to ask for help to see what i need to ask for when i contact someone to repair it for me.
Somewhere along the bottom of the frame you should see 2 slots, probably a few inches in from each end, these are for drainage and allow water to drain through the pvc section and either out over a cill or if one isn't fitted then through face drain hole in the face of the said pvc. Check with water that these holes are not blocked, if you don't use the door often its very likely these are blocked, if so try all sorts like a coat hanger, hose pipe but not too much as you'll flood the house, this is the first port of call.
Secondly i would be inclined to fit a drip strip or weather bar along the bottom of the door itself to deflect rain out over the frame instead of it seeping through the rubber gasket and into the area you highlighted (but this is what the drainage holes are for)
