Water in bottom of DWF416
27 Aug 2008
Hampshire
Does anyone know how to drain the water out of the bottom of the Dishwasher DWF416?
The DW is beeping and not washing and I figure it must be linked to a blocked filter or something.
In short, I haven't a clue.
Blocked filter, jammed pump.
Messy job, but take the filter & remove as much water as you can, its not difficult.
Switch the machine on & the first part of the cycle should be the pump running, try & hear a hum, if you cant hear the hum the pump may be broke.
If you can here the hum, switch off & try & move the impeller, using a small screw drive in the where the filter goes, just put the screw driver down & try to move the impeller both ways.
I have fixed mine that way, if you cant do it that way you will need to remove the base of the machine & remove the pump, its not that difficult, depends how handy you are.
I have a had broken glass & chicken bone jammed in mine.
