I had a mira coda shower installed last August, it replaced a 20 year old mira shower. We have a gravity fed system. The water pressure on the new shower has been very disappointing compared to the old shower. I had to get the plumber back after a couple of months to take a look & he was a bit baffled as to what the problem could be, he cleaned the filters & that improved it a bit but after a few weeks it went very weak again.
I contacted Mira showers a couple of months ago & they sent an engineer who took out the check valves & that seemed to do the trick, the shower was at a pressure similar to the old one, however, the flow has started to drop again & I'm getting a bit fed up with it. Could it be that the filters need cleaning occasionally & is that a job I could do myself?
Would be grateful for any advice.
