What are the building regs for air bricks
14 Apr 2011
Leicestershire
I have a room which is about 10' by 18' that has a chimney (class A) that we want to put a gas fire in. Can anyone tell me if we have to put one or more air bricks in the room and what size they have to be? What do building regs require? Would we need an air brick if we put in a log burner rather than a gas fire?
A log burner or stove will also require a permanently open vent if it’s over 5Kw; the size of the vent you need depends on the stove output & is covered in Building Regs. You will need a flue liner of the correct type for both gas or log/multi- fueled stoves but they are not the same.
Although there are some similarities, the following generic post is more relevant to stoves & open fires rather than gas. Read the links but not all may apply to you.
Installing/re-commissioning an open fire or stove is also controlled building work. Unlike gas, you can DIY instal but you need to understand the Building Regs (which changed in October 2010), submit a Building Notice & pay a fee. Your LABC will inspect &, assuming everything is OK, issue a compliance certificate; the BI may want to witness smoke & spillage tests. No compliance certificate may lead to difficulties when you come to sell your property; if you cannot produce a compliance certificate in the event of a problem, your insurance company may invalidate your policy & reject any claim.
Lots of archive threads on this & some things you need to watch out for, read the links but not all may be relevant or apply to you;
http://www.stovesonline.co.uk/stove_building_regulations.html
http://www.solidfuel.co.uk/pdfs/opening_up_your_fireplace.pdf
http://www.woodburnerwarehouse.co.uk/building_regualtions_for_stoves.phtml
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2010.pdf
http://www.hetas.co.uk/public/certificates.html
http://www.solidfuel.co.uk/pdfs/buidling_regs_consumer leaflet.pdf
http://www.diynot.com/forums/viewtopic.php?t=183614
http://www.diynot.com/forums/viewtopic.php?t=211524
http://www.diynot.com/forums/viewtopic.php?t=242738
http://www.diynot.com/forums/viewtopic.php?t=224751
http://www.diynot.com/forums/viewtopic.php?p=1855590#1855590
& some more sobering reading just in case you think it’s all a load of old tosh:
http://www.solidfuel.co.uk/main_pages/news.htm
http://www.dailymail.co.uk/news/art...wood-burning-stove-leaks-carbon-monoxide.html
http://www.eveningnews24.co.uk/news/warning_over_heaters_after_norfolk_couple_s_death_1_811099
http://www.dailymail.co.uk/news/art...ouple-dead-arms-sofa-overcome-coal-fumes.html
Also get at least 3 quotes from local independent HETAS installers:
http://www.hetas.co.uk/nearest_member
You might be pleasantly surprised & you should ask yourself if you really want all the hassle & risk getting it wrong; climbing onto the roof with an 8M stainless steel snake on your back is not for the feint hearted!
