I'm a newbie and this is my first post!
I live in a Victorian 2 up and 2 down built around 1875. I plan on renovating the back room and originally I wanted to put in a Victorian cast iron range in the chimney breast as I assumed one would have been there before hand.
So far, I have removed the plaster to a width of 125cm and a height of 158cm to reveal just bricks and no lintle!
Also the bricks on both sides are four rows deep so this has put some doubt in my mind that a range was there previously. However, I have pulled out a Victorian cast iron door (measuring 35cm width by 80cm height) that was put up in the flue.
I've attached a photo showing the detail of the plaster that I've removed. I'm not sure if I'd be able to put a cast iron range there or perhaps only a Victorian fire? Would now be the right time to contact a chimney sweep or a builder for advice??
Thanks in advance. Andrew
