Worcester 24CDi combi hot water flowrate problems ????
11 Nov 2009
Liverpool
Hi there
I've been experiencing some problems of late with my Worcester 24CDi combi boiler. The hot water supply starts off at a reasonable flow but then almost immediately tapers off to half this flowrate giving the impression that a filter may be blocked with crud or something. Since moving to the house last year the flowrate has noticeably deteriorated. The hot water dial is turned up high and cold water supply stop cocks are fully opened so aren't anything to do with these.
Does anyone know where i could start my search as i've just recently treated the whole central heating system with an inhibitor so don't want to have to drain down the boiler too many times to find out the problem. This would flush it all away again if the problem affects a common part to the hot water and heating.
Recently changed the diverter valve after the diaphram split so have some reasonable familiarity with working on the boiler but only limited experience diagnosing problems. Any help would be gladly appreciated. Cheers. andy
