what's all this "Logic" ****.
All this "Logic" **** is like, what you have to use with tools and everthing an all sorts, man. Like, pointy things you poke in, got numbers and ****? Well complicated and tricky sort of stuff. Bloody_thing can go fizz and bang and everything an all that. Isn't it.
I am a professional with 32 years experience in the building trade. Not a bleedin numpty......
Serious man, Diss you. Just cos you can like, pile bricks and ****, that ain't squat.
You would have thought, isn't it, like, that somewhere in that like LIFETIME for some African with malaria, and issues, you would have learned not measure boards, like put volts where volts didn't ought to be an everything. That's bone, like really lame and everything and all that? Isn't it?
That Tony, his **** is BAD, Like the geezer you rang. They got years in an everything, and you're dissing them up, bro. They should sue and everything and get compensation. So when , and this is like them to you, "Like measure the ohms and that in the gas valve, from the pcb connector" and you do it when its still connected and change the wrong bit and stuff, that's like, out of order?
You Special Needs?
Isn't it?
Random.
