Hi, hope you can help
I have a worcester 28i Junior Boiler with a problem At the moment the reset button is flashing about 4 times a second.
History:
About 3 months ago the boiler lost pressure and cut out. I re-pressurised the system to about 1.5b. The boiler then happily worked.
yesterday i noticed that the boiler was making all the ususal sounds ie: i think the pump is whuring away but the burner was not on and the reset button was flashing. I have no hot water or CH. The pressure was about 1 so i bumped it up to 1.5 thinking it was the same issue as before. Still not worked.
If i reset the boiler ie: hold the reset button in for 5 secs the boiler fires up for about 5 mins then goes into lock out again.
It does the same if i switch the boiler off at the mains. I switch it back on and it happily works for about 5 mins then locks out again.
Any ideas?
History:
Any ideas?
