- Joined
- 28 Nov 2024
- Messages
- 2
- Reaction score
- 0
- Country
Evening All.
Just had an issue this morning, where my central heating is not coming on when required via Nest TStat.
Removed Tstat connection still the same,
HW is working on demand as expected,
When activating Chimney sweep Mode the heating comes on and radiators heat up, when using the mode twice, boiler temp and pressure just keep rising, until pressure shut off happens, dial comes out of red and once in green the CS mode continues for the timed duration.
With overtemp stat linkout out the temp reads a stable temp of 72.
Any more ideas, Plumber just called out stating its directing to the failed overheat stat reading wrong temp due to failure as everything else is working as is.
No Faults showing on the boiler either so not faulting out or needing reset?
Nest system is all linked and connected correctly to boiler,
No issues for 2 years since moving in to the property with the Nest Thermostat system already installed
