Worcestor Bosch 28 Si II - No hot water! (Sorted)
7 Jan 2010
Cheshire
Hi guys,
hope someone can help. My boiler is a WB 28 SI II and no hot water is being supplied to the taps. No fault codes are showing, and the CH is running fine (I had a PCB replaced around this time last year after the CH failed).
I've reset the boiler, but still no water is coming through at all (cold water is fine, just nothing on the hot taps)? I'm really stuck here, sounds like maybe a pump or something? If the condensate pipe was frozen then surely the CH wouldn' work.
Twice in two years it's let me down, if it's going to cost me £200+ again I'll look at replacing the ******* thing.
Any help appreciated as my two little kids could do with a bath!
***Sorted, I figured no water out of the boiler probably meant none going in - hairdryer on the cold water inlet which was frozen sorted it. Mods feel free to delete post, thanks! *****
