Zanussi jetstream washer
Does the door lock remain closed & the ind led remain lit during those 10 mins.?
You are a bit sparing with your info.
Is the problem is intermittent?
Does it then switch off but has not spun properly when you take the washing out, ie it is still very wet.
If so then I would think that you are having problems with unbalanced loads.
sorry for lack of detail
*does not spin
*does not switch off
*stays indicating 1 min then eventually starts again after about 10 minutes
*happens every wash
*thought this indicated blocked filter but empting pump is not running during pause and filter is clear
