First post but often read the helpful info here.
Thought I'd run something past the forum..
A little history:
Over the last year or so been getting kettling from the boiler, started with cleaner/silencer etc, keeps coming back after a while.
Got a plumber in who just changed the pump and balanced the radiators.
Recently we lost the hot water, which turned out to be the 3 port valve stuck, which I replaced, and because I drained the system I noticed the header was quite mucky, dark brown with bits of black sludge.
I've filled it up with cleaner again but now want to find out what is causing it and if I'm going to need to get a power flush?
Now I've learnt, from reading here I may add, that it looks as if the system is pumping over, also learnt that the plumber probably shouldn't of set the pump to 3 on a small 3 bed house
I set the pump to 2 and the vent pipe was still getting hot, now another thing I read here is the height of the vent, it looks as if the vent has droped off it's clips into the header tank the end was submerged, would this be a cause for the over pumping? I had no idea that it had fallen off as I didn't know where it should be in the first place
So......I'm going to leave the pump on 2 and see what happens, but I'm wondering if the vent being in the header is causing damage to the system hence the noise etc?
Thanks.
A little history:
Thanks.
