I'm looking for advice on my plan to insulate under my groundfloor floorboards. I've trawled the archives/search and some come to a similar conclusion as myself but I wanted to confirm it with the masses.
The groundfloor is all suspended flooring with a good sized crawl space (i can sit up in it!).. At somepoint in time the crawl space has been concreted and additional air bricks installed. Now at the moment we're slowly doing the house up (have been for the last 9yrs *sigh*) so pulling the floorboards won't be a problem, agro but not a problem.
So my question? What is the recommended solution for insulating under timber floors? I initially thought rockwool of some form with netting or something holding it close to the top the joists. But would kingspan/celotex or even the insulation slabs might be a better solution (eliminating the netting.. But perhaps needing another way to fix say battens fixed to the joists?)
Eventually when all is done some form of wood flooring will be being laid throughout the groundfloor..
Any advice/guidance very much appreciated.
Rob
Rob
