I don't know whether anyone can help me or not with my heating problem.
I have a Potterton 40e Netaheat Profile boiler and it is a gravity system. When my programmer is set to JUST hot water the boiler strikes up nicely and I get hot water. When the programmer is set to JUST central heating the pump runs but the boiler doesn't strike up and all the radiators remain cold.
With both running together only the hot water function is running.
Before Christmas I desludged the system, flushed and flushed again and then left inhibitor in it and since then it was working fine. To try and remedy this problem I have bled the system, drained and refilled under pressure to try and get rid of any airlocks but to no avail.
Could this be the over run thermostat ? Or perhaps the over heat thermostat not allowing the boiler to come on at all ?
Thanks.
Thanks.
