Rover 45 brake light bulb
1 May 2003
Durham
Volunteered to change one of these for someone, expected a flap as the old 200 series, opened the boot, nothing.
Does this mean I have to strip the side panels out just to change a bl00dy bulb ? HELP !!
probably.
vauxhall astra to change tail lamp
empty boot of "stuff"
remove flap
insert hand through apperture
cut hand on appureture
pull hand back through apperture
stick plaster on cut
reinsert hand through appperture
undo nut at top (nothing happens)
find nut at bottom
undo nut
still nothing happens
pull light cluster
light cluster come off in one piece
undo lamp
remove lamp
insert new lamp
reverse procedure
takes about 10 mins
gone are good old days
you may want to see my post about headlamp on renault if you think thats bad
