My CH system is playing up. (Gravity fed system with Gloworm Ultimate 120FF, two motorised valves, bypass valve and TRVs on each rad.) The symptoms are kettling every 10-15 minutes. This has only started in the last couple of weeks. I have read the FAQs and checked a few things and I think the most likely culprit is sludge build up in the heat exchanger. I have about 20 rads in the house and some have the tell-tale build up in them but we have just lived with it for a few years. My plan is to remove them 1 by one in the spring and flush them through with a hosepipe. I have tried power flushing twice before with little success (once myself and once with a plumber).
I thought that the problem was air in the system initially as I have had some building work done and rads removed. I have bled the air though with little improvement. I also guess that the inhibitor strength will be low as this has not been topped up since the builder left.
I have checked the pump, the motorised valves and bled all the air out of the system but I still can't get the rads very hot or the kettling to stop.
I am loathed to touch the system for a few days as HW is OK and the rads get warm (and I mean warm only) which keeps the chill off. (I have two small children so I need some heat and HW).
My plan is to drain down the system partially and add some Central Heating cleaner & sludge remover (I have some stuff called Flushex which recommends being in the system for 4 weeks). Then flush through and refill with Sentinel Inhibitor.
Am I wasting my time or do you think it is worth a go? I also need to find a decent plumber in the Basingstoke area. I have only ever got two from Yellow Pages and they had no idea.
Thanks in advance for any advice.
