Please could you advise.
My girlfriend has been living in her flat for 4 months, there is no gas to the Flats and the water is heated an immersion heater.
The unit has 2 elements on the side one below the other, it has 2 power switches on the outside of the cupboard, the top one has a light on it and is a sort of a rocker switch, the bottom one is a normal switch, I can see no external thermostats, the cylinder is large and coated in a green foam, and has a black plastic lid on the top and looks very good condition, the flats are only 10 years old.
We have normally left both the power switches turned on and not touched them, and the system has been very quiet and worked well.
Last night I could here a noise like a kettle boiling and this was going on for some time, I left this but the noise continued, so I turned the bottom switch off, the noise stopped strait away.
I left this of all night and the in the morning switched this bottom switch back on; strait away it started the kettle noise again. As though the water was at temperature
Please could you advise me on this, the temperature has not changed much in my area over the last day, to suddenly do this, we have not touched any of the setting or the switches. please could you explain this system and how the twin elements work, and the best way to go about diagnosing this, I have meters and all those sort of things.
Thank you
Darren
Thank you
Darren
