If I put a small pump say 2 bar pressure pump on the hot water output and then connected the cold supply to mains.Is this a practical solution to try to inprove water pressure cheaply.
if your supplys are tank fed, then obviously it will be better.just be warned, as i mention to customers going to a pressurised from gravity system.it could cause problems with old pipework.best to check pipework first.
