Unless its on gravity.the tap water has nothing to do with the systems water and overheating boiler.
Profiles/Primas are prone to boiler stat failure. Get that checked first by a RGI.
Dunno what we have sorry,try to explain it.Main water tank in loft,much smaller tank below this.We have to leave at least one rad open in summer when just having hot water on,again i dont know why,was told to doby someone engineer probably!Immersion heater that we never use,presume this holds the hot water when its heated,hope this explains it a bit.Sorry not technical terms,but i am a good painter
Could be linked if HW is red hot, and Boiler stat on lowest possible setting, and system is gravity and it o/htg could be that the boiler stat is fooked
