The thing is, it looks kind of ugly,
You're not wrong there. How much did your brother pay for it?
Shouldn't worry too much about the pipe either. Is the place ex local authority?
That pipe devalues the property. No-one has the right to do that without permission. Cut the bogga off.
Cut the bogga off.
You can't go banging clips in walls that aren't yours.
A totally empty statement. Provide independent proof if you want to raise your credibility.It devalues the property no-end. Get rid.
So i'm guessing 3 pages on that it's got to stay there?![]()
I wouldn't worry about it.
There will be a white Transit cruising around the area soon, with the driver and passengers doing meerkat impersonations. The pipe will be removed during the night shortly afterwards.
The dogs may bark, but the caravan moves on.
You obviously forget how a T&P relief valve operates.............are you registered to fit unvented? (G3)
Yes, that was not totally correct.
If the pressure was normal and the valve had operated because the temperature had reached 95C then it would probably vent about 20% of its capacity.
Because of the way the heated water convects to the top it will only be the upper part of the cylinder which is at the 95C to open the safety valve so as soon as the slightly cooler water below reaches the valve then it will close again.
The reality is that a properly installed cylinder never reaches an unsafe temperature and the only time any water might be discharged would be when or if the expansion device does not adsorb the expansion during heatup when no water is being used.
Apart from the Megaflow when that can occur, on other makes which are correctly serviced each year it would not normally ever happen.
Tony
