working fine then one morning, wining noise on starting- no hot water no heating no pilot light, it start as if you are going to get hot water and stops after 15 seconds the green light start to flash fast. model biasi M90e 28s any help??. i called a gas safe engineer and he inspected the boiler, the fan rotate freely if the boiler is off, when switched on it seizes! does that mean the fan needs replacement?, the engineer did not check (by Ohm meter ) to see that there is any resistance across the coil ,makes me unhappy about his opinion.thank you.
i need help in this issue.
Robert
Robert
