Morning all I hope you might be able to help me!!
Basicly this summer I replaced the diverter diaphram and hot water heat exchanger, no real issue just a pain of a job. System ran fine.
However came to but the CH on and noticed a slight weep from the filler loop, which I fixed last night.
Re-test and had steam coming out of the air vent and a lot of banging..... I realised that the cirulating pump had become disconneted, I've re connected drained and refilled.
No the issue is I get the boiler clicking in if its on CH or Hot water, but the radiators or the hot taps are only look warm! if I restrict the flow of water out of the tap then it does warm up.......
ANy idea's I did wonder if the pump has failed but it does spin and i do get a bit of water out of it. Could it be this at fault or is it the expansion tank or is it just an air lock in the heating matrix??
Many thanks in adavnce.
