D
Deleted 205484
I took off a 2 gang, 1 way light switch to replace with dimmer and stupidly didnt make a note of the wires - I remember that some of the black wires are in a connector block going nowhere, there was a loop between the common.
I have one live wire (Red) coming up as part of T&E and then I have 2 other T&E going to the light fittings (I believe) as part of the continuing ring.
I put all of the black wires together in the connector. Put the actual live into the common, put a loop across to the other common and then connected the other 2 red wires to L1 in each switch.
I now get one of the kitchen lights working but not the other and my hall lights will only switch on when I have the switch on in the kitchen whereas before they were independent of each other.
Where have I gone wrong - I have checked the stickies and other forums but am still stuck!!!!
Help...
Help...
