Hi there,
I noticed a similar problem someone else had with this model,
Have an Indesit IDF125 dishwasher and it has started to not work, once I switched it on and pressed run, you hear some motor starting, then goes quiet, you can then hear water coming into the machine, then it sounds like its draining out, then the 3 lights start flashing as in the picture below, so sorry for the blurred picture but you can see the washing indicator light, the end indicator light and the start/pause button indicator lights all flashing together, I was wondering if its the same problem as the gentleman in this post with a similar problem,
//www.diynot.com/forums/appliances/indesit-idf125-flashing-lights.329270/
I have attached some pics of the model sticker as well.
Any help would be appriciated
