Hi, my immersion heater trips the rcd when it turns on via an immersion heater timer switch. I can run the immersion on manual and it works fine but when it clicks on via the timer function it trips the rcd. If I change the timer switch will it stop the rcd tripping?? If not can I put the immersion heater circuit on the non rcd side of the DB??
Thanks in advance
Thanks in advance
