My experiences are very similar. I, too, started at a very early age and, in my mid teens, was playing with transmitting equipment which sometimes had HT voltages of around 1.5 kV. However, the only couple of 'significant' shocks I experienced (40-50 years ago) were from 240V AC.I started "playing around" with electrics and electronics at an early age, so like most reading this have had a few shocks over the years. Despite years of working with all sorts of equipment and voltages well up into the thousands in transmitters and similar equipment (where one tends to be quite careful), the worst shock I ever recall getting was 240V AC from a string of Christmas lights when I was about 14.
That's the point. Again, like you, I have experienced a number of 'tingles' from 240V AC over the years, but 240V (and, indeed, 120V or less) can, and occasionally does, kill - so we are all essentially just 'lucky'.And yes, I've had other brushes with 240V over the years which really were nothing more than a tingle, but that's the point: Just because one run-in with 240V AC results in nothing more than an "Ouch!" doesn't mean that it can't do a lot more damage in other circumstances.
Well a farmer I used to work for had a bit more of an experience. The fence energiser came from New Zealand and was designed to run many miles of fence wire - and deter wooly sheep. We only used the 1/2 power terminal, but could still get good sparks from it.but what really hurt is when i tried to clamber under a cattle fence and lent down with my hand on the ground and my shoulder touched the cable,apart from the crack of noise it hurt like hell.and i assume that was 50 volts???
You've obviously never accidentally had neutral in one hand and live in the other. Not only was it bloody sore, I could even feel my brain scrambling. I consider myself extremely lucky to have survived that one. Anyone who asks if 240 is dangerous might want to visit a man in a white coat before one in a black cloak carrying a sythe comes visitingseriously I am not trying to be funny but I have had several shocks from 240v and it does nothing more than tickle you. even touched both live and neutral once nothing really dramatic happened just a bigger tickle and hurt a tiny bit but not a lot.
let me know what your opinions are. maybe 415v or 11kv will probably kill you stone dead. but tbh 240 aint that bad.
Not teaching my grandmothers how to suck eggs, but hence the old electricians' watchwords: keep one hand in your pocket!Just to add that the worst shock I can remember having was as an apprentice working on some motor control panels. I was fault finding on it, and touched the end of a loose live wire, while touching earth with the other hand.
Simpson did actually manufacture and market some of its range in Britain at one time, certainly the ubiquitous model 260 and some of its relations in the 1960's/1970's. Among the various Simpson meters I have, I have at least one, if not two which were made in England.put his "Simpson" test meter (so not in the UK)
As the old saying goes, electricity is a faithful servant, but a dangerous master.It's so easy to become complacent when you're working with electricity day in, day out and forget how just how dangerous it really is.
Nice one !And I thought we got some stupid questions in the Plumbing Forum but this OP should be a candidate for the Darwin awards!
Oh well... let natural selection take its course.
Yes indeed, and very valid words they are too! I can't remember exactly what happened, but I probably leaned in and put my hand on the side to steady myself. I should have known better before. I certainly did afterwards! Having a decent belt off it certainly does increase your respect for electricity.Not teaching my grandmothers how to suck eggs, but hence the old electricians' watchwords: keep one hand in your pocket!Just to add that the worst shock I can remember having was as an apprentice working on some motor control panels. I was fault finding on it, and touched the end of a loose live wire, while touching earth with the other hand.
