- Joined
- 27 Jan 2008
- Messages
- 23,669
- Reaction score
- 2,667
- Location
- Country
Fitted an outside lamp, then bored so started to read the instructions. Learnt nothing I did not know, but it was the lengths they go to trying to make them idiot proof, and in that attempt make them worse.
"latest IEE Wiring Regulations BS 7671" how long has it been IET?
"this product is also subject to Part P" does not this depend on where you live? and it would likely also be subject to Part L as well!
"ln case of doubt seek advice from a qualified electrician." and you really think if you ring a qualified electrician he will guide you through the work?
"TURN OFF POWER TO THE LIGHTING CIRCUIT AT THE CONSUMER UNIT BEFORE INSTALLATION." but it's simply plugged in!
"The halogen floodlight must be mounted on a stable outer wall made of a non-flammable material and must not be used indoors." tell the builders that!
"The halogen floodlight must not be used with a dimmer." good advice at last.
"CAUTION! Use only HO5RN-F,3G,1.0mm² cable or better." Now what DIY guy will understand that, ask of heat resistant, or round cable yes but that load of letters will only mean anything to electricians. Oh I suppose this is where you ask the electrician?
"Tools required: Hammer drill, Phillips screwdriver, screws and rawlplugs appropriate to the mounting location." and you will tighten up the terminals with what? You may get away without the hammer drill or rawlplugs, but you will need a terminal screwdriver and likely something to strip the cable with.
"BROWN is for LIVE" how long has it been called line for?
A lot of the instructions were good, warning about not touching the tube, the amount of heat it generates etc. But in their attempt not to miss anything it means anything missed becomes more important and there are just too many options to try and include it all.
"Turn off power" is all that was required, "TURN OFF POWER TO THE LIGHTING CIRCUIT AT THE CONSUMER UNIT BEFORE INSTALLATION." has assumed you connecting to lighting circuit which may not be the case.
8. Not suitable for use in extreme conditions. While the floodlight offers basic protection against mechanical aggression and splashed water it should not be exposed to extreme weather conditions such as hail showers. (Yes and your really going to run outside and bring it in when the weather turns bad?)
How can any outside lamp be not exposed to extreme weather conditions such as hail showers? To say not suitable for an exposed location like on top of a pole on the Yorkshire moors OK. But it says not suitable for indoors, not suitable for hail showers, and subject to Part P so clearly for the UK.
So the question is all instructions too comprehensive and should manufacturers provide more basic instructions and expect the person using the equipment has some prior knowledge?
