Hi
Is this electrical feed to a shed safe?
A double plug socket inside the house has a plug in RCD connected to it. From this RCD a short 2.5mm 3 core rubber flex cable goes through the wall in to a waterproof junction box mounted outside.
Inside the waterproof box the flex connects to 2.5mm armoured cable which runs underground 30m down the garden and then up the shed wall in to a waterproof box from inside which a 2.5mm flex cable goes inside the shed through the wall.
From there it splits off to a double plug socket and a 5a fused switch which goes to a LED light.
Is this safe or can it be improved? The only thing that can't be done at the moment is moving the feed from the plug socket inside the house.
