Hi everyone.
I’m looking at putting temporary power to my shed before I book an electrician to put a permanent supply there For lights and power.
I usually run an extension lead to Power my battery charger for my motorbike. I’m thinking of doing this on semi permanent temporary basis.
im thinking of running a caravan 2.5mm hook up cable around the perimeter of my garden behind shrubs. Then route that into the shed to an RCD double socket. The mains plug would be a caravan hook up adapter to 13amp plug into the existing outside waterproof double socket. This has its own fuse on the consumer unit.
I would need to drill a hole in the wall of the shed to route the cable. What type of waterproof grommet/gasket would I need.
would the socket in the shed need to be a waterproof socket?
