wired systems use 6 core cable
Me again. Why would systems use six cored cable? Is it for convenience, or is this just an off the cuff generalisation I've taken out of context? If it is, please disregard this question.
As I see it:-
six cores = PIR contacts + traditional tamper + power
but, considering this thread //www.diynot.com/diy/threads/are-shunt-eol-resistors-common-these-days.461357, there are other possibilities:-
two cores = surface contacts + shunt /EOL resistors
four cores = surface contacts + traditional tamper
four cores = PIR contacts + shunt /EOL resistors + power
eight cores = smart ass active sensor with power + masking, fault, latch etc. outputs.
12 cores = for professional ??? ( http://www.electricaleurope.com/en/gb/CQR-Brown-0182mm-12-Core-6-Pair-Round-Professional-Copper-PVC-Intruder-Burglar-Alarm-Security-Cable/m-747.aspx )
Clearly there is a cable cost differential and if a job is priced lean, you might use alternate cables for different sensors within a single project. So why six..?
