toilet install - what would you do?
31 May 2016
If you realised that you'd mis-measured the fitting for a loo pan connector fitting, and now the rubber/plastic connector was protruding through the floor and is too fat for the loo to fit round, what would you do?
A - tell the customer of your mistake and find an alternative loo that had a wide base that would fit.
B - redo the pan connector raising it up and shorten the bend.
C - grind a bit of the base of the loo on the inside so it fits.
D - make up some "amusing" spacers out of bits of old copper pipe and clips and install the loo 2.5cm away from the tiled wall
see below: the work of a pro :(o_O
Would need to see what the pan connector location etc looks like to comment on what could be done.
Ultimately, the connection should be made up correctly, with the correct fittings to suit the appliance. That's the only option that should be considered IMO.
I'll take a pic but the soil pipe connector seal is too big for the space in the back of the loo. so it's stopping the pan being pushed flush to wall.
loo was delivered ages ago so no excuse that it was unknown.
When I got home - he'd done C. If I'm honest - its what I'd have done. But then I'd have been saving the money paying a professional to do the install.
Jesus, I know, could he not at least have sprung to a couple of tap washers ffs :LOL:, the screws aint brass either ;)
IMO, closest that person got to being a plumber was .... slept with one :sneaky:
See all sorts of bits like that being used inside the cistern everyday.
And it makes me mad coz my prices are pitched against prices from ppl who do that sort of shyte! And the customer just doesn't know until it's done - then the problems start!
