Probably the original was a Crabtree 9049 skirting box.
http://www.ebay.co.uk/itm/Crabtree-...rting-Back-Box-1-Gang-32mm-Deep-/160934034970
You could replace the existing socket with that and a blanking plate, and extend both the cables up separately to a new socket, so keeping the new socket on the ring.
Thanks but I think my mum wants something better looking. But never thought about turning upside down.Or you could always turn the socket upside down. Yes it is a cr4p idea but it'll solve the problem of trying to get the plug inserted
Thanks so is it OK to extend the wires ? Do I just use a block and the same type of wire?
That's not really necessary. One cable from connectors to socket will suffice, i.e. three conductors in each L and N connector., and extend both the cables up separately to a new socket, so keeping the new socket on the ring.
A blanking plate is unnecessary - the socket above will create a cable zone, so a maintenance free JB could be put into that cavity and the skirting board made good.You could replace the existing socket with that and a blanking plate, and extend both the cables up separately to a new socket, so keeping the new socket on the ring.
