Apologies if this is in the wiki/faq, but I couldn't find it...
I have a traditional (non-combi) boiler, which both heats the radiators and provides hot water, but in the summer, it would be useful to have hot water only. Obviously, I could turn off all the radiators in the house. But when I moved in, I was told something about a 'tap' (round head) in the airing cupboard I could turn which would switch between hot water only, heating on or both (I think).
Does that sound right / normal? I'm a bit reluctant to use them, as they turn quite a bit way both ways and getting back in the right position might be tricky. Would anyone be kind enough to explain how this works? And (assuming it is what I think it is), can you have anything fitted to make it easier to switch between hot water only or heating and hot water?
There's a shelf immediately above the hot water tank, and the first picture is above and the second below. Then there are two more pictures taken from as far back as I can - the best I can do, sorry (the shelf can't be removed). Not sure what any of those taps do, so any advice much appreciated...
Many thanks in advance
